0 members (),
149
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2019 Posts: 51 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 51 | This topic must appear somewhere on here but I can't seem to find search results.
1951 Chevy 3600 216 Rochester B Carb
New fuel pump installed last week and everything was great until yesterday. Truck sputtered and stalled but quickly recovered by pumping the accelerator and I made it to work. End of the day It restarted and I made it home with no issue. Today same story... started right up, went to work okay but coming home it sputtered a bit then stalled, and now will not maintain an idle.
It restarts fine. Pumping the accelerator pedal keeps it going but it stalls and stops when letting of the gas to idle.
If anyone can suggest a diagnosis page I'd be glad for some direction. If you have a good inkling about the problem I'd like to hear your theory as well. Thanks, Rog | | | | | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | (1) Defective electronic conversion in the distributor (2) Burr on points changing both dwell and timing (3) Partial clog of idle circuit in carburetor.
Jon Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Gonna choose (3).
When changing the fuel pump, you might have had some trash enter the line and make it's way to carb and settle in the idle circuit. | | | | | Joined: Mar 2014 Posts: 4,504 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,504 | I'll side with Roy...particularly if there's no filter between the pump and Mr. Rochester. It is possible even though the pump is new that some junk was inadvertently left inside when it was assembled. Have you had previous trouble with the carburetor and idling?
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | Here's a sneaky trick that has worked pretty often for me. Open up the idle mixture screw a couple of turns, then rev the engine up close to cruise RPM and either close the choke or clap your hand over the top of the carb. Do this several times. If there's a tiny bit of debris stuck in the idle circuit, the quick shot of high vacuum will draw liquid gasoline through all the passages in the carburetor and maybe flush it out. If it works, fine- - - -readjust the idle mixture and press on. If not, you're going to have to open up the carb and put high volumes of air through every passage to clear the clog.
I hope you didn't use thread tape on any of the fittings of the new pump- - - - -tiny slivers of that stuff love to clog carburetor passages! Jerry
| | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | Jerry, do you recommend using any type of sealant on the fittings between the fuel pump and carb inlet?
-Patrick 1953 Chevrolet 3100 261 / 4-speed / 4:11 / Commercial Red
| | | | | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | Not Jerry, but NO! on the sealants. New fittings will seal. If you absolutely certainly cannot sleep at night if you didn't put something on the threads of the fittings, then 1/2 drop of blue loctite.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | Brass fittings with pipe threads in aluminum castings shouldn't require any type of sealer. Just don't overtighten them and crack the casting. A long time ago, I used to use a product called "Leak-Lock" which was designed for high pressure refrigeration fittings. It was a thick liquid that resembled blue Loctite. Using sealer on fittings that operate at the pressure of carbureted fuel systems is pretty much redundant. Jerry
| | | | | Joined: Jul 2019 Posts: 51 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 51 | Thanks all; No troubles previous and I first also thought debris upon replacing the fuel pump. And no to tape thread. I'll try my luck at the suggestion from HotRod Thanks again! | | | | | Joined: Mar 2014 Posts: 4,504 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,504 | Re: the thread sealer question...please remember your fuel pump should not produce more than 4 psi...5 at the very most and 2.5 is in my experience just perfect for a 235 or 216 with a 1bbl carburetor. You aren't dealing with the same 50 to 80 psi your city water supply provides.
