4 members (Mr Crosswrench, RLB, klhansen, 1 invisible), 108 guests, and 3 robots.
Topics128,133
Posts1,056,395
Members48,441
#137330 02/28/2007 5:57 PM
I'm getting mixed information from different reps at a reputable dealer about the need (my want) to attach a front sway bar to a Heidt's IFS w/ power R&P on my 56 TF.
I understand the benefits, but will I really notice the difference after the installation of my IFS? What about installing a rear sway bar?
Opinions, rants and stories welcome.
Paul
1956 Chevy Task Force Webshots
My wife puts knots on my head faster than I can rub 'em. That's why I ask knot-headed questions.
#137331 02/28/2007 8:10 PM
Junior Member
Junior Member
How does the truck handle now? You will notice a big difference in handling with the sway bar on. I personally don't rear sway bars on drivers. On a tow rig it helps though...
Josh
Truck Werks
6315 S. Kyrene Rd.
Tempe, AZ 58283
480-838-1166
#137332 03/01/2007 2:25 PM
I am an advocate of front and rear swaybars...whether it be an IFS setup or a straight axle.
Controlling body roll and improving both low and high speed handling has been proven again and again. Once you drive a rather top heavy 50 year old vehicle without bars, and then with front and rear bars you're going to be sold on their use.
Care should be taken to MATCH the bar size (diameter) with your vehicle....too large is as detrimental as too small. If you use them on the front you need them on the rear and vice-versa.
If your vendor doesn't offer a bar then you'll need to do some R & D on your own. The rear bars on pickups are not that rare...on the front you'll probably have to hit the yards...and fabricate/modify the mounts. Either way the addition of front and rear bars, will improve the handling of your truck. Hope this helps.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#137333 03/01/2007 8:07 PM
Dave -
Thanks for taking th time to reply. I always been on the path of putting both front and rear sway bars on my 56. So getting different stories from different folks at the same dealer threw me off to recosider before buying anything.
I have yet to install the Heidt's IFS and most likely check with Heidt's on the front sway bar, before scouting around other dealers.
Josh -
As for the current drive, it drives like a 51 year old skate board with the metal wheels on a railroad track. It's in desparate need of a front end job, whether stock or resto mod. But I still love to drive it.
Thanks -
Paul
#137334 03/02/2007 5:16 AM
As far as other dealers, as a suggestion check out www.jimweimerrodgarage.com they pretty much have everything and the prices are great. The guys there set me up with a custom IFS and air ride for my 51 D*dge. (I used them because they were local for me, pointed me in the right direction and saved me money in the long run!)
if you want, check out my projects here: http://www.hotrodders.com/forum/journal.php?s=&journalid=22733&action=view
Let me know what you think!
#137335 03/02/2007 6:48 PM
Junior Member
Junior Member
Paul, I think rear sway bars are a preference thing. I think a front should be mandatory but it depends on your spring setup. Its easy enough to rebuild the front end and put a sway bar up there and if you need better handling you can always build a rear sway bar.
Truck Werks
6315 S. Kyrene Rd.
Tempe, AZ 58283
480-838-1166
#137336 03/06/2007 9:05 PM
Truckwerks -
I tend to agree with you on rear sway being a preference. I'm definitely going to install the front sway bar and will need to noodle on if I want the rear sway bar.
Thanks all for the input.
Paul
