Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 172 guests, and 1 robot.
Topics128,274
Posts1,058,433
Members48,490
The window regulator gear that the handle fits on is worn down and the handle does not fit snugly and slips when attempting to roll the window up or down. Is there any solution other than replacing the entire regulator?
What year truck are you asking about?
Harold
Harold
1953 GMC
Moderator, Electrical Bay
If you are capable of metal work/machine shop work you might be able to make one, but it will take some work and time. Otherwise I think you'll have to replace the entire regulator.
~ Jon
Insomniac
Insomniac
A previous owner "fixed" the shaft on one of my regulators by filing a flat area on it making it into a D shape. The set screw on the handle contacted the new flat area.
The real problem was the handle. It's made of softer material than the shaft so the teeth were worn out. A new handle was the proper fix.
Make sure the problem really the shaft; not the handle.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
