| | | Forums66 Topics128,057 Posts1,055,812 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | The window regulator gear that the handle fits on is worn down and the handle does not fit snugly and slips when attempting to roll the window up or down. Is there any solution other than replacing the entire regulator? | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | What year truck are you asking about? Harold
Harold Is a restoration ever finished? | | | | | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | | | | | | Joined: Mar 2014 Posts: 4,482 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,482 | If you are capable of metal work/machine shop work you might be able to make one, but it will take some work and time. Otherwise I think you'll have to replace the entire regulator.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jul 2000 Posts: 2,191 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,191 | A previous owner "fixed" the shaft on one of my regulators by filing a flat area on it making it into a D shape. The set screw on the handle contacted the new flat area.
The real problem was the handle. It's made of softer material than the shaft so the teeth were worn out. A new handle was the proper fix.
Make sure the problem really the shaft; not the handle.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | |
