1 members (mick53), 202 guests, and 1 robot.
Topics128,115
Posts1,056,288
Members48,439
#1372311 08/06/2020 5:31 PM
8
8 Offline
I have a '56 chevy 2ton, open diff creates issues when I'm stuck, it'd sure be nice to have a locker in this thing. Besides spinning only one tire, on a small slick hill parking it with the parking brake on (just holds the driveshaft) it'll also roll forward with an open diff (wheels can turn in opposite directions).
Doesn't look like anyone makes a drop-in (or "lunch box") locker for these? Anyone ever try to adapt one to it? Seems like it might be doable with some custom machining. Maybe I'm crazy haha but I love to mod/improve things.
Something like this, and adapting it to the correct axle size/spline:
[img]https://www.speednik.com/files/2017/05/2017-05-18_04-35-28.jpg[/img]
https://www.drivetrainshop.com/v/vspfiles/assets/images/spartan_install.jpg
I haven't had the rear open yet, so maybe it's just all wayyyy to big to even try a locker made for a dana 60?
thx for any advice,
Gary
Moderator
Moderator
2 Offline
A welder will make it a locker real quick!
Don't ask me how I know!
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Crusing in the Passing Lane
Lincoln locker.
Ed
8
8 Offline
HAHA yeah unfortunately I can't weld it up, I still haul big loads with this thing so that'd be an unmitigated disaster when turning on a hard surface with 5 ton of gravel on the back!
There must be some other solution?
Have you considered buying tires with some tread on them? It's highly unlikely that every big rig that's ever been produced in the past 75 years or more would have been able to haul untold millions of tons of cargo if all of them really needed a locker to get the job done!
8
8 Offline
I have brand new 10R22.5 retreads! Nice tires. The other day I was in wet grass and had to back up a hill with a full water tank on the back. Right tire spun out and there I sat. Most of my trouble is on ice in the winter though, and it always spins one side immediately and then all momentum comes to a stop. An icy slope is also where I had a problem with the parking brake not holding it, since it's an open diff. Creates a dangerous situation. Again, this is all with very nice tires on it. I can send pics if you'd like to see them.
I live in the mountains, lot of steep terrain and snow/ice/mud.
I should also mention I swapped the engine with a new BBC with 525ft-lbs of torque, that doesn't help, haha.
8
8 Offline
Originally Posted by 2-Ton
If you have a heavy load and need a locker, You shouldn't be there in that truck!
Like Jerry said, New mud grip tires should do it and have a Ford to lead the way out!
Let the bashing begin!
Don
HAHA smile
Moderator
Moderator
2 Offline
A set of chains will be your friend then!
Don
"The Flag Pole"
1953 1-ton pickup
Maybe you need a driver? I saw a Peterbilt with a 425 Cat and too much traction put three full turns into a piece of 4" driveshaft tubing one day. It was bogged down in a muddy rice field and the throttle jockey revved it up and side-stepped the clutch. The driveshaft ended up looking like an hourglass.
8
8 Offline
HAHA I'm not side stepping the clutch or using a bunch of throttle.
Would a better driver help the issue of parking brake on a slick hill not holding it? Maybe you should show us your skills in fixing that problem, Einstein.
Maybe not being on the hill in the first place might be an option? Einstein wouldn't have put three times the engine he needs into the truck. It got along quite well for a few decades with a 235, or maybe a 261 in it.
A stronger throttle return spring might help. Detroit lockers come for big truck diffs., might be worth changing diffs. to one with a locker.
Might be able to get by with just hanging out 3rd. member?
Ed
3B Offline
Hy 8flat, Years ago I purchased a "Detroit locker" for my 57 Chevrolet one ton and over the years I acquired a 1959 Chevrolet Spartan 100 Chevrolet dump truck with a two speed Eaton rear axle which was also equipped with a "Detroit Locker, or No Spin" rear axle. So they were out there and available at one time, maybe an Ebay search will turn something up, or post an ad in the parts wanted forum.
8
8 Offline
Ed
Thanks Ed, I took a look at Rockwell but that's more of an involved swap than I'd like. There might be others that aren't so spendy though.
8
8 Offline
That's interesting, I had no idea it was an option on these, very cool. I'll check around, thanks
8
8 Offline
Don
True, I do need a set for winter.
Have seen school buses from the '50 that had No-spin axle, may have only been on single speed axle as I recall.
BC
1960 C60 pasture art
Play nice Jerry.
Professional Novice
8
8 Offline
Interesting, I wonder if they were a clutch-based limited slip design? It'd be fun to find one...
Detroit Lockers are a specific product, not a generic product, they do not have slipping clutches, sometimes called harsh, but they work.
Ed
Interesting, I wonder if they were a clutch-based limited slip design? It'd be fun to find one...[/quote]
No clutches, built like this (have one in my newer K2500)
https://www.randysworldwide.com/product/yglgm14t-30/
BC
Google 'Detroit locker' Eaton comes up, follow along there.
Ed
8
8 Offline
Update: It appears that Eaton still makes a "NoSpin" locker for our rear ends, pretty cool news. This is assuming I have an H110 rear in mine, I need to confirm. The one-wheel wonder days may be in my rear view mirror!
Eaton part number: 250S-27
https://www.eaton.com/content/dam/e...ospin/eaton-nospin-application-guide.pdf
3B Offline
Hy 8flat, thanks very much for the link, I hope you find something that fits.
