6 members (klhansen, Otto Skorzeny, Charles in CA, Peggy M, Gray_Ghost, edgardo), 79 guests, and 2 robots.
Topics128,059
Posts1,055,825
#137279 02/20/2007 1:29 AM
Junior Member
Junior Member
I'm in the process of putting a 4 link suspension on my 48 half ton gmc pick up. It has a mustang 2 front end that I will be putting bags on and I'm also running bags in the rear. I have already installed a 8" c-notch. To get the proper pinion angle for the truck should it be set at ride height but I have already removed the rear end and installed mustang 2 front end. How can I get the proper ride height? I want the truck to set on running boards @ the lowest point.
Thanks for any suggestions ps 350 sb and tubo 400
already installed what would be a good tailshaft
pinion angle?
#137280 02/20/2007 3:40 AM
Do I understand you correctly? You say you want the truck to set on the running boards at its lowest point.
You probably intend to show it setting that low, but won't drive it any distance while that low. Unless you are on a perfect surface you'll be throwing sparks and wearing things off. That's not very practical.
Wouldn't it be better to determine the height you want to drive it most at, and set the pinion angle at that height.
#137281 02/21/2007 3:08 AM
With a parallel four link system, the pinion angle does not change with ride height. Just set the pinion angle so that it is parallel to (equal to) the transmission output shaft angle. Do NOT aim the pinion shaft at the transmission shaft.
#137282 02/23/2007 12:15 AM
Junior Member
Junior Member
THANKS GUYS
robin 58 the video made a lot of sesence
