1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 27 Junior Member | | Junior Member Joined: Dec 2005 Posts: 27 | I'm in the process of putting a 4 link suspension on my 48 half ton gmc pick up. It has a mustang 2 front end that I will be putting bags on and I'm also running bags in the rear. I have already installed a 8" c-notch. To get the proper pinion angle for the truck should it be set at ride height but I have already removed the rear end and installed mustang 2 front end. How can I get the proper ride height? I want the truck to set on running boards @ the lowest point. Thanks for any suggestions ps 350 sb and tubo 400 already installed what would be a good tailshaft pinion angle? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Do I understand you correctly? You say you want the truck to set on the running boards at its lowest point.
You probably intend to show it setting that low, but won't drive it any distance while that low. Unless you are on a perfect surface you'll be throwing sparks and wearing things off. That's not very practical.
Wouldn't it be better to determine the height you want to drive it most at, and set the pinion angle at that height.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | With a parallel four link system, the pinion angle does not change with ride height. Just set the pinion angle so that it is parallel to (equal to) the transmission output shaft angle. Do NOT aim the pinion shaft at the transmission shaft. | | | | | Joined: Dec 2005 Posts: 27 Junior Member | | Junior Member Joined: Dec 2005 Posts: 27 | THANKS GUYS robin 58 the video made a lot of sesence | | |
