Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (54farmtruck, UtahYork), 48 guests, and 6 robots.
Topics128,003
Posts1,055,244
Members48,418
#1372209 08/05/2020 8:22 PM
I have a 49 GMC pick up with 6 lug GM Rally Wheels with a ZC code. They were with the truck when I bought it as a stalled project. I think they mabe from a 80's Blazer, but not sure. I'm getting a bit of wheel rub on the outer edge of the fender when I hit a bump. I need to replace the wheels with a different offset. I don't know what to look for as I don't have and can't find a code chart that lists the ZC code so I can determine what I have.
Does anyone have a chart or can you direct me to one. I've contacted a local tire shop but they haven't replied yet. I'd like to determine what the ZC code represents as well as determine what code to look for as the replacement.
If interested there are pictures of the truck (as well as my other 2 projects) on my Facepage Tom Strojinc.
tswillow #1372220 08/05/2020 10:24 PM
Crusing in the Passing Lane
A measuring device does not require codes.
Ed
tswillow #1372234 08/05/2020 11:52 PM
I understand I can measure my wheels if I take them off, but that doesn't help me with determining what wheel code I should be looking for.
tswillow #1372245 08/06/2020 1:00 AM
Just a thought maybe not the wheel ,could it be front end lowered or spring sagging ?
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
KEVINSKI #1372267 08/06/2020 4:47 AM
Or maybe just switch to a smaller tire to prevent rubbing? It would sure be faster, cheaper and easier than switching wheels.
And your truck looks great with those wheels BTW.
1951 Chevy Panel Truck
KEVINSKI #1372489 08/07/2020 8:47 PM
Sorry, should have stated, its the rear wheels. and thanks for the compliment on the look. I want to keep the rally wheels, just with a different offset.
tswillow #1372510 08/07/2020 11:51 PM
Insomniac
Insomniac
Try asking Wheel Vintiques. I believe they can build you some rally wheels with the offset you want. They might even know what a "ZC" code is.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
tswillow #1372859 08/10/2020 10:31 PM
Thanks for the lead, I just sent and email to Wheel Vintiques. I'll update this post when they get back to me.
