6 members (Bill Hanlon, Gdads51, Otto Skorzeny, UtahYork, dt235sd, Ponchogl), 115 guests, and 5 robots.
Topics128,089
Posts1,056,130
Members48,435
#1371926 08/03/2020 3:18 PM
As some of you may know im attempting to build a custom 54 gmc 350 AD truck but, i have always wanted a spartan or viking after seeing a repurposed firetruck spartan turned into a rollback car hauler coupled with the fact i grew up riding around in a 56 1/2 ton pickup im just in love with they way they look. Can anyone tell me how much wider the frames are in the front on the spartans or vikings? I may have the chance to get my hands on either one but the seller is not able to get up and around like they used to and it is too far away for me to run over and measure. i know they came with a big block v8 so it has be be wide enough to fit that in there, and before i take on a second and possibly third project are there parts available for these trucks? Sheetmetal, fenders, grille components etc or is it more than likely id have to track down a good original part to replace them with?
THE BLACK VIKING
1958 Viking 60 ~ my new toy hauler
My Current fleet: 1954 chevy 3800, 1953/4 gmc 450 coleman 4x4, 1956 chevy pickup, 1958 Viking 60
Keep 'em rollin fellas!
Rustbucket Ranch
Rustbucket Ranch
Not sure about 60-61 Vikings and Spartans, but during 58-59 the frame widths are pretty much the same throughout Apache, Viking and Spartan. The cabs, hoods, and inner fenders are the same while the Vikings and Spartans had the wider fenders, grill and grill support. Those parts aren't reproduced.
1949 Chevy 3100 (In the family since new)
1955.5 Chevy 3100 - in the DITY Gallery - (Dad's truck)
1955 Chevy 6500 - in Big Bolts - (Possible parts truck?)
1958 Chevy 3800 w/9 ft bed - in Project Journals - (Current project)
1959 Chevy Spartan 10400 - in Big Bolts
I'm confused as to what trucks your are trying to compare...are you trying to put a 58/59 frame under your '54 GMC or are you trying to compare the '56 1/2 ton pickup to the 58/59 Viking/Spartan's?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
this is what i needed, i have a 56 1/2 ton i can measure off of to get a close idea
THE BLACK VIKING
Mike B smile
No sir, just trying to get some sort of engine bay dimensions so i dont run into the same issues with the spartan or viking trucks as i am my 54. being super narrow limited engine options and just a whole list of issues. basically trying to see if these would be easier to build into what i want, if thats the case ill go back to stock on the 54 and just spend the money elsewhere on one of those trucks.
THE BLACK VIKING
Former Workshop Owner
The Vikings and Spartans were designed to accommodate a V8 engine. So, you are good to go. The AD trucks were only available with an inline 6. That's why you are limited to only a few engine choices (inline 6's) without having to make a lot of changes.
Good luck.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Crusing in the Passing Lane
Lots of people install V-8’s where there once was a 6cyl.
Ed
Ed
I tried a mock up with 2 different engines and the blocks wouldn't fit between the frame rails. so i am going 6 cyl diesel. for the AD, and if i snatch up one of these trucks i mentioned i will be able to have even more options for a motor.
THE BLACK VIKING
