0 members (),
122
Mod | | | Forums66 Topics128,271 Posts1,058,314 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2018 Posts: 167 'Bolter | | 'Bolter Joined: Feb 2018 Posts: 167 | I'm installing a disc brake kit and the bottom bolts that go through the spindles and into the steering arms have to be drilled from 7/16" out to 1/2". I bought some cobalt bits and was able to drill the spindle holes pretty easily. The steering arms are a whole other story. I've destroyed four expensive bits trying to drill these things. Come to think of it, I'm constantly destroying drill bits. Is there some trick to drilling steel without going through $100 worth of drill bits? Or is that just the way it is? I try to go slow, use some oil.... but no luck. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If the chips are blue, slow down the bit, use lubricant.
Ed
| | | | | Joined: May 2015 Posts: 11,262 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,262 | Enlarging holes is hard on twist drills, as the force is concentrated on the tip of the bit. If you're using a hand drill motor, you're probably binding and breaking the bit cutting edge because it's hard to keep them aligned. To successfully drill these, you probably need to clamp them in a drill press, center the existing hole, and has been said go REAL slow with plenty of lubricant. Another option is an adjustable reamer, taking just a tiny bit off each pass, and adjusting the reamer until you get to the desired size.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,940 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,940 | Use a drill press, slow the cut down, and step-drill the hole bigger about 1/32" at a time. Use a good quality lubricant like Rapid Tap or Tap Magic, or plain old 30 weight motor oil if nothing else is available. A can of STP and a pound of unsalted lard makes some of the best general purpose cutting oil available. Mix the STP with the lard until you get a stiff liquid a little thicker than honey that clings to the drill bit when it's applied with a small paint brush. Mix half a cup or so at a time, and your supplies will last a few years. When the chips get hot on a heavy cut, that mix smells like bacon frying. Jerry
| | | | | Joined: Feb 2018 Posts: 167 'Bolter | | 'Bolter Joined: Feb 2018 Posts: 167 | Yes, you guys hit the nail on the head. Its getting very hot and binding like crazy. I'm using the lightest pressure but still grabbing. Ha! unsalted lard?? I'll have to ask the wife about that one. I'm not from the south.... Thanks for the advice guys, I'll give it a shot. | | | | | Joined: Feb 2004 Posts: 29,940 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,940 | Your local "Habla Espanol" restaurant uses it by 50-lb. cans in most of the food they serve, particularly refritos! If you ask nicely, they'll probably give you some! Jerry
| | | | | Joined: Mar 2014 Posts: 4,520 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,520 | Or any Hispanic grocer. They've started carrying it in little tubs (like softened butter) in fact. But don't look in the refrigerated section. It will usually be in the aisle with baking supplies...next to Crisco, shortening, etc.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
