1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2020 Posts: 114 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 114 | got the gasket set for my 1952 216, came with a dought-nut gasket for between manifold and ex pipe, the one I took out was a flat diamond shaped gasket, which is correct ?
woof359 Family 1952 3100 5 Window
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Look at the flange on the exhaust manifold. Does it have a flat surface or a 45 degree chamfer on the inside diameter? The exhaust pipe will have a corresponding shape, either a flat flange welded to the pipe, or a sliding flange and a cup-shaped bell in the pipe. Use whichever gasket mates with the manifold and exhaust pipe properly. Jerry
