6 members (39Master85, papas52, Jack Ryan, 1955 1 Series, BC59, JW51), 54 guests, and 2 robots.
Topics128,083
Posts1,056,326
Members48,442
Hello,
I disassembled the 235 cui engine of my Chevy Pickup build 1953. Today I tried to start the engine. I put the choke half out and pulled on the starter, he worked well.
After a few turns of the engine the carburetor make a big bang and the carburetor smells of petrol. After this bang i tried it again, but the engine wanted to start.
I think its a problem of the poistion of the ignition distributor.
Here you can see how the ignition distributor is fixed on my engine:
https://www.kripahle-online.de/unterricht/wp-content/uploads/2020/07/img_3537.jpg
How should the distibutor be fixed? Can you send in your answer a picture? Or another question how must I turn the distributor to "A" or "R"?
Ask
Wolfgang
I'm working on a Chevy Pickup 3600, build 1953 with an 235 cui engine.
Here you can watch my truck: https://www.kripahle-online.de/unterricht/?page_id=2532
Insomniac
Insomniac
It's good where you have it set now. For setting the timing, see Hotrod Lincoln's post from a week ago:
https://www.stovebolt.com/ubbthread...iming-marks-on-flywheel.html#Post1370265
Gord 🇨🇦
1954 1/2 ton 235 4 speed
If the distributor doesn't solve things, then another thing to check is intake valve lash.
Backfiring and hard start can occur if intake valve lash is too tight.
.008" intake and .016" exhaust worked for my solid lifters. Those are cold adjustment numbers.
'59 Chevy Suburban, NAPCO
Hello Ott3r,
the valves are fixed with a setting tool. I think I need a rough attitude to fix the distributor and let the engine run and attitute the ignition with a timing light.
Wolfgang
The engine started
