| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I constantly read inquiries about speedometer problems when doing T5, other overdrives, transmission, rear end, and tire size changes. This can be remedied SO EASILY with a gps speedometer where whatever change is made makes no difference to the speedos accuracy. I keep waiting for a supplier to make an attractive bezel insert to complete the swap. No gears, no cables, just a dead accurate speedometer for under a hundred bucks. Ones who live where there are tunnels say they work there also.
Evan
| | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | GPS speedo app on phone make it easy to dial in a mechanical speedo. Drive 50 mph & see where the speedometer reads. difference either = or - , times 2 will give the % either plus or minus. With that info either do the math on drive / driven gear or get a speedo adapter. Some of us have several different ratios adapter rat holed, post what you need and might get a free one!
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jul 2019 Posts: 559 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 559 | Yup thats how I set up mine on my 3/4 ton with the BW OD. I figured out which stewart warner ratio adapter would work and found it on ebay for a decent price. Ended up with a .8974 conversion. It runs pretty much dead on now at 65mph. The most it is off at slower speeds is 1mph or less. Works nice and smooth after a good lube on the speedo head and warner box. | | |
