4 members (Stovebolt48, Steelonsteel, Bill Hanlon, lumbersawyer), 31 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,422
#1371033 07/28/2020 6:45 PM
Where can I get a 235 Head for a 1954 BelAir motor? Are all 235 heads the same? Thanks, JS
Pieman #1371035 07/28/2020 6:52 PM
The 235 head was changed in 1956 to the higher compression "858" head.
That head will work in place of earlier 18 head-bolt 235 heads (1954/1955).
Pieman #1371036 07/28/2020 6:54 PM
A 1956 and later head will have a larger hole for the temp sender, but a common adapter is available.
My Blog
Pieman #1371304 07/30/2020 12:54 PM
Tim, I have a stock 56 235 on a stand. It needs a rebuild. Is there any power advantage if I put the 858 on my 54? Ed
Pieman #1371312 07/30/2020 1:36 PM
Don't you mean 848 head?? Bill
Pieman #1371314 07/30/2020 2:09 PM
The low compression head can be milled .090" to make it have the equivalent compression ratio as an 848 head, but some other modifications must be made such as recessing the intake valves the same distance to prevent valve to piston contact. It's also necessary to make some modifications to correct the rocker arm geometry.
Pieman #1371325 07/30/2020 3:24 PM
Yes Bill, slip of the finger or of the brain, Jerry, we have a saying here in The South.....If it ain't broke don't fix it. I will leave well enough alone. Thanks for the reality check. Ed
Pieman #1371335 07/30/2020 5:36 PM
Rebuild the 56 and put it in instead of the 54. Little better compression, non-shimmed bearings and neoprene rear main seal. But to answer your question, yes, you will get a little bump in compression and theoretically a speck more power. One other thing to keep in mind though is that the spring pressures are different amongst the various heads. 55 for example used two different pressures depending on the motor and the transmission. So you may want to check the spring pressure on the 56 head and compare to the 54 to accommodate what the factory designed for the cam.
Mike
