Last night (and I see another thread here with exactly the same axle leak so that answered one question) I pulled the rear drum off my 3600. I had already noticed from the backing plate that someone in the depths of time had converted the rear brakes to Bendix. I found a part # on the wheel cylinder FD-14495, should be easy enough to find something on that front. Looks like it was used in hundreds of applications.
The rest of the assembly, I'm not sure. My question is, to make it easy on the parts folks, what vehicles are folks using for the Bendix brakes on these? They measure 12"x2" I did some Googling and there are a number of options out there, but I'm not 100% sure if I can actually just stuff the parts from any 12x2 brake set in there.
I attached some photos below, but they look like every other drum brake assembly under the sun
although that parking brake mount on the backing plate might strike a chord?
Thanks!
