11 members (52Carl, carbking, Gdads51, Bill Hanlon, 1955 1 Series, 2-Ton, Robert Crandall, fonz8261, greenie-reddy, 2 invisible),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,124 Posts1,056,347 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | Recently, I was pleasantly surprised to find that a stock 235/75/16 tire on a factory wheel would not fit under the bed of my 3100. What is the size of the spare tire that came original on our trucks? I "assume" the wheel was the same size/width..?
-Patrick 1953 Chevrolet 3100 261 / 4-speed / 4:11 / Commercial Red
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 |
| | | | | Joined: Aug 2019 Posts: 242 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 242 | Not sure what original is... I've got a 215/85/16 under the back of my 3100 burb. Around a 16x7 wheel same as the others.
'59 Chevy Suburban, NAPCO
| | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | So...I just mounted a brand new 215/70/R16 onto a factory rim, and it still will not fit under the bed of my truck. The crossmember hits the sidewall of the tire before you can raise the spare tire holder/carrier up and fasten with the large nut. I've moved and re-arranged the tire as much as you can, it simply will not fit.
My truck is a '53 model, which has the spare tire carrier angled at a 45 degree angle, unlike the earlier trucks that have the spare tire carrier that comes straight out the back and J-hooks onto the bumper.
What am I doing wrong?
| | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | Can you swap out the bolts for longer ones front and back to give you more room for your fatter than stock tire?
| | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | I'm going to look at it more tomorrow, that might work.
