2 members (Wooley, 59 fleet),
70
Mod | | | Forums66 Topics128,096 Posts1,056,488 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2018 Posts: 5 New Guy | | New Guy Joined: Dec 2018 Posts: 5 | Hello, was wondering if the exterior cab body only was the same for 39-41 half ton trucks, Interiors are different but concerned about the cab body doors windows etc, Thanks | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Salty B, welcome, as far as I am aware the actual body and its parts were the same from 1939 to the 47A series, hope that helps. | | | | | Joined: Dec 2018 Posts: 5 New Guy | | New Guy Joined: Dec 2018 Posts: 5 | | | | | | Joined: Jul 2006 Posts: 36 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 36 | actually there are differences 39-40-41. the 39 cab has no drain holes in the windshield corners, the windshield regulator comes out in a different spot(horizontal instead of vertical) the 40 is similar to a 39 with the exception of the 2 previous things. the 41 is different at the cowl/firewall the firewall actually sticks out 1 1/2 past the cowl compared to a 39-40 firewall that is flat. if you are asking because you want to interchange the front ends you will have to do some modifications to make the hood latch stuff work. | | |
