3 members (78buckshot, Phak1, Gdads51), 81 guests, and 2 robots.
Topics128,093
Posts1,056,475
Members48,444
#1369941 07/21/2020 2:30 AM
Hello, was wondering if the exterior cab body only was the same for 39-41 half ton trucks, Interiors are different but concerned about the cab body doors windows etc, Thanks
3B Offline
Hy Salty B, welcome, as far as I am aware the actual body and its parts were the same from 1939 to the 47A series, hope that helps.
Thanks, The hunt begins
actually there are differences 39-40-41. the 39 cab has no drain holes in the windshield corners, the windshield regulator comes out in a different spot(horizontal instead of vertical) the 40 is similar to a 39 with the exception of the 2 previous things. the 41 is different at the cowl/firewall the firewall actually sticks out 1 1/2 past the cowl compared to a 39-40 firewall that is flat. if you are asking because you want to interchange the front ends you will have to do some modifications to make the hood latch stuff work.
