5 members (Bill Hanlon, baldeagle, Stovebolt48, WICruiser, wilbur53), 145 guests, and 3 robots.
Topics128,038
Posts1,055,471
Members48,424
#1368587 07/10/2020 10:50 PM
I have a rebuilt 1950 216 motor. Which oil would be best to use?
Valvoline VR1 SAE 30 Conventional Motor Oil or Valvoline VR1 SAE 10W-30 Conventional Motor Oil
I like Valvoline because it is high in Zink which is what our "babies" need.
Harold
Harold
Harold46 #1368605 07/11/2020 12:21 AM
Moderator, Electrical Bay
Honestly Harold I prefer the straight 30 weight VR-1 in either the 216 or the 235. It does have enough zinc and the price is better than many of the others out there. Hot here. Hope it is cooler over your way.
~ Jon
Harold46 #1368620 07/11/2020 1:17 AM
I'll just repeat the joke one more time...
"The viscosity number, or the number before the "W", is the time in seconds for oil pressure to reach the last bearing in a cold engine.
10W30: 10 seconds
Straight 30: 30 seconds
Harold46 #1368974 07/13/2020 10:00 PM
Ex Hall Monitor
Ex Hall Monitor
I never heard that before. While the lower viscosity number does mean it will reach the bearings faster because it's thinner, I'm curious now if it has anything to do with the number of seconds in a one for one or just a simple measurement of time to empty a zahn cup. Since the flow rate would depend on the ambient temperature, distance it has to travel and height it has to lift in the different engines I doubt it's a one to one ratio. I have some research to do it seems.
Harold46 #1368978 07/13/2020 10:34 PM
“Joke”
Harold46 #1368982 07/13/2020 10:51 PM
How about today's 0W40 oil? And since the Stovebolt engines have the oil pump in the middle ... which is the last bearing? Maybe we could amend the old joke to the time it takes for the rear main seal to start dribbling? Although I've never been convinced some of them ever stopped dribbling.
~ Jon
Ex Hall Monitor
Ex Hall Monitor
Originally Posted by Justhorsenround
“Joke”
Ah, I see said the blind man.
Tiny #1368992 07/14/2020 12:16 AM
To the deaf mute, as he picked up his hammer and saw.
Brian
1955.2 3100 Truck
Harold46 #1369280 07/16/2020 1:44 AM
The number before the W is the number of seconds between drips from the rear main seal.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
