| | | Forums66 Topics128,095 Posts1,056,480 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2020 Posts: 148 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 148 | Hi all, first post here after many late nights sifting through all the good info here! I just acquired a 1949 3600 and will be doing the 16" wheel upgrade that's been discussed many times on here. The truck has modern 15", nondescript modern rims and 235R15 polyester radials on it now. Plan A is the simplest: buy a set of 16" x 6.5" .5" offset Dexstar rims from eTrailer: https://www.etrailer.com/Trailer-Tires-and-Wheels/Dexstar/AM20766.html#exp-productdetails=.questions and put on a set of either 215 or 235/85R16's on. This was the solution discussed in the 2015 thread here: https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1158249/1.htmlAccording to the Tire Calculator ( https://tiresize.com/calculator/), with the 215 rubber, I'll get a diameter (30.4") almost exactly the same as the original bias ply on the optional 17" wheels that you could buy in 1949. With the 235 rubber I get an extra inch of diameter (31.7" actually). The goal for me is to get a bit more highway speed. The 235's should improve my speed for the same RPMs by 9.9%, while the 215's improve it over the existing tires by 5.2%. This is all to just tide me over until I get around to doing a ring and pinion swap in the rear end (if I can find the parts). So two questions: 1. Anybody have rubbing or fit issues with the 235's? Is the truck still steerable or is that too much rubber on the road? Carl52 advised in this current thread that 16x8 would be too much, but I get the sense that 16x6 with 235's is ok: https://www.stovebolt.com/ubbthread...-wheel-question-52-3100.html#Post13680332. Has anybody tried fitting 17" wheels on a 3600? With a tall radial that might be worth a fifth gear! :-) Thanks for the help! Pops
| | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | I have 17" artillery wheels on a 1/2 ton. Harder to steer for parallel parking and tight places but ride quality is excellent, radial tires, of course.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | My '48 3/4-T had three 700x17's and one 750x17 (old bias ply) tires on it when I bought it. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jul 2020 Posts: 148 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 148 | Hey Cosmo, what diameter did you end up with running those artillery wheels? Do those things bolt right on or do they need modification? | | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | PapaD,
235 75R 17 = 30.88, I believe that is officially 'Poor Man's Overdrive' Territory.
| | | | | Joined: Jul 2020 Posts: 148 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 148 | Some diameters and a summary of wheel numbers I've read, both from here and elsewhere.
235/75 R15 = 28.9" Pretty close to the original wheel diameter on a 3600 235/85 R16 = 30.5" Almost exactly the same as the optional 17" wheels you could originally order 235/85 R17 = 31.7" Picks up an inch over the original 17" option, 3% better (lower engine speed for same MPH) than the 234/85 R16 and 13% better than the 235/75 R15
3 1/2" backspace is a must (if you want to avoid using spacers) according to the prior posts on this board, although some members indicate that 4" backspace might do if you have the 1 ton tie rod ends. It's close to impossible to find the 3 1/2" backspace (Dexstar trailer wheels are the popular recommendation: 16x6 8/6.5), so it would be nice if we could squeak by with 4" as well.
Bolt pattern spacing is 6.5" which is 165.1mm, not 160mm as is sometimes stated.
Lots of guys say that Ford rims work, but I've not had much luck confirming backspace just from websites selling them. Either the data is not listed or when it is the backspace for the listed rim is greater than 4".
Grigg posted on here about using 19-19.5" wheels. He was using bias ply truck tires, but if you could put a radial on those they would be a whopping 34.7" in diameter for a 235/85 R19. That would be awesome if you could fit all that under the fenders! | | | | | Joined: Jul 2020 Posts: 148 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 148 | Will a 19" wheel completely clear the tie rod end on a 3600? The 16" rim looks like the tie rod is about 1" past the diameter of the rim or right at rim/tire interface. So a rim 3" greater in diameter might clear the tie rod end completely . . . | | |
