1 members (UtahYork), 88 guests, and 2 robots.
Topics128,142
Posts1,056,491
Members48,442
#136873 01/20/2007 5:02 AM
I have the factory power brake booster in my 64 1/2 ton with automatic trans, and am in the process of converting from drums in the front to discs. I have been told I can use the existing booster add a dual outlet master cylinder and proportioning valve to do this, but it seems that the existing booster would not have the same output as a later one designed for discs. Anyone know if I can use the existing booster?
#136874 01/20/2007 1:38 PM
I have on mine,, pic here used a 71 C10 manual brake master & a CPP prop valve. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#136875 01/21/2007 4:21 AM
Why did you use the manual master cylinder, and does it stop well?
#136876 01/23/2007 11:53 PM
The power master has a differentt pushrod setup than the original booster-it is more flush fitting whereas the OE booster requires a longer pushrod. I'm sure it was due to many power boosters that were added at the dealer level-they used the same master 63-66 for power or manual. Brian
