4 members (sawdust54, G508, Peggy M, Uncles51), 86 guests, and 3 robots.
Topics128,028
Posts1,055,414
Members48,422
#628274 03/12/2010 4:14 PM
I'm not sure if this is the proper area for this question but here goes. A few weeks ago I purchased a set of correct 16" rims with 3 clips for my 59 Napco 1/2 ton. When I received them I noticed one of the clips was broken off. My question is, is there a way to rivet a new clip from an extra rim or am I better off just welding/tacking it on since the hub cap will cover it? I plan on having the rims powder coated after Im done.
Thanks again,
Brian M
BrianM #628338 03/12/2010 6:55 PM
Don't ever weld on the rims not good practice. The original rivets are impossible to find use a machine screw with a self locking nut they work just as well.
Brad Allen #628378 03/12/2010 9:54 PM
Thanks. I'll stay away from the welding.
Brian
BrianM #628410 03/12/2010 11:19 PM
Here ya go, Brian
How to install hubcap clips
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
LAROKE #628821 03/14/2010 5:53 PM
Thanks again. That will work for me.
Brian M
BrianM #921352 02/20/2013 11:13 AM
Ok, so why not tack weld them on? I can't imagine that it'd be so much heat that there'd be warping of any kind.
I wouldn't mind using the machine screws, but I'm just curious.
OldDawg
BrianM #921366 02/20/2013 11:45 AM
the clips are springs, easily 'dis-tempered' by heat, that's probably why the factory didn't weld them on
BrianM #921370 02/20/2013 11:51 AM
Here is one example.
Welding weakens a wheel, said Marvin Bozarth, a technical consultant to the Tire Industry Association. "The wheel is designed to operate at certain temperatures, and sometimes when you weld on it, the metal hardens and causes fractures that may not be visible," Bozarth said. Such damage can lead to the wheel failing.
"Don't weld them; don't hit them with a steel hammer," Bozarth said. "You've got to treat them nice and make sure they're in good condition."
Yet despite such warnings, some wheel welding does go on, Bozarth said. "I see it on some wheels," he said, surmising the practice continues to be performed by "people who are just not informed, don't listen, or they think they know better."
He added, "That's what gets people killed."
I stated and I stick by the statement welding on wheels is not good practice (best left to pros) Also these clips are made from hardened steel, welding on them will soon lead to them breaking off at the HAZ (heat-affected zone) in order to manage this process you need post weld treatment (heating the wheel) again not best practice, and a crap shoot for a non-professional at best. In addition any welding or heating of wheels calls for the removal of tubes and tires. Why bother with all that just drill and use some attachment hardware.
BrianM #921375 02/20/2013 12:03 PM
Great, thanks for the good info.
OldDawg
LAROKE #1368006 07/06/2020 7:05 PM
Tbone
Tbone
Laroke-
I like the chrome beauty ring look. Where did you find these and how well do they fit-up? I'm going to 16x8 wheels to make room for front-end disc brakes.
BrianM #1368007 07/06/2020 7:07 PM
Tbone
Tbone
Sorry, one additional question. Where did you buy your extra clips? I was going to look on Jim Carter's site.
BrianM #1368205 07/08/2020 1:51 PM
I actually have a handfull of clips i removed from ¾ton wheels that were on a 53 chassis. Im also in Pgh. Pa. If you need em? Im not 100% sure they're the right ones tho. Bring a wheel with ya if ya decide to take a look. Pm me
BrianM #1368212 07/08/2020 3:18 PM
There are a few million wheel running around with the centers welded into the barrel instead of the old method of riveting them in. Welding on spring clips is still a bad idea, however.
