0 members (),
93
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 27 Junior Member | | Junior Member Joined: Dec 2005 Posts: 27 | I have install a stock mustangII front end in my 1948 gmc 1/2 ton . dont know what it came out of Iam going with air bags my ? is it has like 9 or 10" rotors on it know asumming they are ford. has any body swap for chevy rotors and where did you find them. next I just bought a 4 link kit from jegs has any body got any experiance in the installtion. I am puting in a 8" heavy c-notch in also. and Iam uaing 2b7 airlift bags. in the frount and rear. thanks for any knoledge. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You might check with Heidt's, I believe that they make a spindle for the mustang 2 front end that uses GM itermediate rotores and calipers. It's supposed to be a bolt on setup.
Bill Burmeister | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | You can also get after-market Mustang II rotors that have the Chevrolet bolt pattern.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Oct 2003 Posts: 2 Junior Member | | Junior Member Joined: Oct 2003 Posts: 2 | Acutally, if you have Mustang II spindles, there are forged brackets available to mount 10.5" GM rotors (4.75 bolt pattern) and mid 80's GM calipers to those spindles. Stainless Steel Brakes Corp and Progressive Automotive have these. Probably a few other companys as well.
P.S. I've heard of a few problems with the flame cut steel brackets not fitting and bending. | | |
