| | | Forums66 Topics128,266 Posts1,058,367 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2000 Posts: 116 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 116 | I've just finished welding in some replacement panels that were coated at the factory with black EDP coating. I want to prep the panels for painting first with epoxy primer, to be followed by primer and finish coats. My question: what is the proper preparation for the panels coated with EDP--does it need to be entirely removed, scuffed, or what?
Thanks in advance for your help!
Jim | | | | | Joined: May 2015 Posts: 11,266 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,266 | I did some checking around on various web sites and it seems the consensus is that you can shoot epoxy primer over EDP, after scuffing it a bit with a scotchbrite pad. I would also wipe down with wax and grease remover. Check to be sure it's really EDP by wiping with a lacquer thinner soaked rag. If it comes off, it's not EDP.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2005 Posts: 4,263 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,263 | If you can take it down to metal, why not take it down to metal. This way you'll know exactly what you have. I recently bought some patch panels for a roadster I'm working on. I noticed, when I sanded the coating off, there was rust underneath. Needless to say, I removed all of the coating and removed the rust. | | | | | Joined: May 2015 Posts: 11,266 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,266 | If you can take it down to metal, why not take it down to metal. That's a good option as well. Then you know what's underneath your paint.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2000 Posts: 116 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 116 | Thanks for your replies--I think I'll take them down to metal just to be extra safe. | | |
