1 members (baldeagle), 91 guests, and 5 robots.
Topics128,014
Posts1,055,327
Members48,419
#136759 01/14/2007 5:33 PM
I saw a picture where the builder used a radiator cap that was mounted in line with the top radiator hose next to the thermostat housing.
It looked like tee with a radiator cap on the top.
I'm using the stock radiator out of my 1979 Chev.
Mounting it behind my lower grille. I need something like what I saw in the pic so I can access the cap, because the cap on my radiator will be innaccessible.
I need to know what that item is called and if anyone knows where to get one, it would be appreciated.
#136760 01/14/2007 6:55 PM
I think you saw it on the LOWER hose.Check out the system on a 2004 Chevy truck.They use a nice "T" in the lower hose(suction side)up to the overflow tank.Check your local junk yards for wrecked trucks.
Good luck!
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#136761 01/14/2007 8:02 PM
I've seen what you are talking about. Most of the ones I've seen are made by a radiator shop using an inline pipe with a radiator neck welded or brazed to it. I would check with a radiator shop to see if one can be made up using the correct size pipe to fit with the size hose you have.
If you have one made up, the neck used might be from a later model vehicle and the neck might be a pressurized neck that will use a pressurised cap. You need to be sure your radiator will hold the pressure you are expecting it to hold. A 79 Chevrolet radiator will accept quite a bit of pressure, but I would be sure it is in good condition.
Joe grin
#136763 01/14/2007 10:55 PM
TooMany2count,That Moroso brand remote fill looks good and it does go in the upper hose.The set up I have seen is orignal late model Chevrolet truck and is T'ed into the lower hose.
Wanted Good Woman:
#136764 01/16/2007 4:30 AM
Thats what I was looking for. I'll check the wrecking yards, if they don't have one I'll order the one made by Moroso.
Thanks guys. cool
#136765 01/16/2007 9:33 AM
Junior Member
Junior Member
They are available from several Race Car parts suppliers."Speedway Motors"in lincoln,Ne. carries them but you may have to look in there Dirt Track/Sprint Car Catalog.They have a Online catalog.
BAN LOW PERFORMANCE DRIVERS...
NOT HIGH PERFORMANCE CARS !!
