1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
In looking for an engine for my 54 project I have a family friend that has offered up a 92 Chevy 350tbi and a 700r4 tranny. I like the fact that I know this guy and know that he takes care of his vehicles. His son in law was going to use the setup in one of his projects but decided to go a different route. His son in law was not planning on using the tbi setup so he paid no attention to pulling associated wiring and what not. So it’ll be a carb setup if used. I’ve been thinking about using this setup in the 54. I wanted to see if fellow members have gone this route?
I know I’ll need a new intake and carb. A bracket for the carb for the TV cable on the 700r4. An HEI distributor, electric fan and I believe the cam has the lobe on it for a mechanical fuel pump. I think that’s most of the items needed other than a few smaller pieces. And the new mounts of course for the frame which came with the truck when I bought it.
I also have an option for a 396 out of a 69 chevelle that my cousin had machined and the lower done when he decided to buy a performance crate engine. It’d need basically all top end and looking at that Im thinking that project might be over my budget but might be a nice one to keep in mind for the future if I decide to do a full on resto on this truck.
As much as I’d love to buy a crate motor and slam that in price wise that’s just not an option at this point. I know sbc’s are very common and can be had all day long on the popular sites, Craigslist and Facebook marketplace, but most are pulled and they say “ran when pulled” but I’m not comfortable with not hearing them run and trusting a stranger. I like that the one setup I’m asking about since it’s a family friends. Any thoughts on the setup are appreciated. Thanks
Adam
Adam
Someone may correct me but I believe that starting in 91 GM started using a 4L60E vs the 700R4 transmission. Which meant it was operated using the computer that operated the engine systems. The 700R4 (aka 4L60) does not use the computer controlled valve body. There are aftermarket wire looms available to use the throttle body and the later transmissions. Also some diagrams available to use the original wiring and required factory components. That block does not use a manual fuel pump, the casting is there but does not have provisions for a pump.
Fred
