3 members (kurbside bolter, JoergK., klhansen), 160 guests, and 1 robot.
Topics128,266
Posts1,058,369
Members48,485
#136755 01/14/2007 1:03 AM
Apprentice
Apprentice
I would like to redo the rear suspension on my 57 Chevy 1/2 ton. Years ago I did the Mustang II front suspension and mono leaf springs and QA1 shocks in the rear , i've never been real happy with the mono leaf springs ride. I'm not looking to raise or lower it anymore , it sits just right now, it measures about 2 inches between the edge of the fender to the top of the rim.
What I was wondreing is what all you guys have tried for rear suspension and liked or disliked?
I'm open for anything, air bags, coilover, 4 bar, new leaf springd under the axle ?
I don't use my truck for hauling much weight mabey 500 lbs.
Tell me what ya think , Gene
#136756 01/15/2007 12:32 AM
If you still have the stock rear springs you can remove 2 or 3 leaves, (like maybe 1,2, and 4 counting from the axle up), that will bring it down about 2" from stock. If you need more drop than that you can take the modified springs to a spring shop and for less than $100 get them dearched to whatever ride height you want. This will really soften up the ride. You can run air shocks if you plan on carrying much of a load. To get even a smoother ride put poly or teflon liners between the leaves.
#136757 01/15/2007 12:57 AM
Apprentice
Apprentice
I have Mono leaf springs now, can't take any more leafs out !!!!
They are dearched with reversed eyes. Truck sits just right now.
Just looking for suggestions on other types of suspension setups other people have tried for the rear of their pickups
Thanks , Gene
#136758 01/17/2007 5:30 AM
i have a four link from cpp. it went together good and seems to be of good quality. but if i had to do it again i would have got a triangulated four link. so i wouldn't have to hav a panhard bar. my truck isnt running or driving yet so i cant tell you how it rides. but thats just what i would do.
it's not old it's "aged to perfection"
http://brent5631.myphotoalbum.com/
