2 members (55shaker, 1 invisible),
313
Mod | | | Forums66 Topics128,152 Posts1,057,011 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | Good morning everyone. I recently removed the top cover on my SM420 transmission. Just to see the condition of the gears inside. They look great! Now I don’t have a clue on how to put the cover back on so it will shift through all the gears. I went on YouTube. There are videos on how to take the transmission apart, but nothing on how to put the cover back on. Can anyone of you help me out? A video on how to? A link to a page? Anything would be greatly appreciated. Thank you all for all your help. Elmo | | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | That’s great Brad, but it really doesn’t show where to fit the shifting forks. Elmo | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | Look at picture #43...see the groove in the hub on the left side of the gear set and the groove on the large gear on the right? That's where your two forks ride...just slide the hub and gear back and forth on the shaft until the forks and grooves line up. Mike B  | | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | Thank you Mike B, that helps me out tremendously! Elmo | | |
