4 members (greenie-reddy, Jon G, cmayna, dt235sd), 26 guests, and 4 robots.
Topics128,021
Posts1,055,372
Members48,420
Started the rewiring in my 49 3600 and realized I never was sure how the ignition switch is actually supposed to mount? The bracket in the picture, when I got the truck, was just on the floor and the ignition switch was hanging by its wires.
I've seen pictures that show the switch in different locations; I had installed it in that hole above where I'm holding the bracket and it fits fine. But what is right, and if the switch does go in the bracket, what goes in that big hole in the dash?? There is also a small hole in that bracket - I read somewhere a light goes there?
Any information on that is appreciated! Thanks
1949 Chevrolet 3/4 Ton - Still Solid. Regular Driver
OT Vehicles:
1925 Hudson Brougham Super Six
1950 Chevrolet Styline (Parts)
1952 Canuck Pontiac Sedan Delivery (Well Underway)
1973 F250 4x4 Highboy
1977 F250 4x4 Lowboy
Jim Carter shows this
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Interesting... that curve doesn't match the curve of the dash which throws me too (it's the reverse curve - meaning that can't fit flush, or even bolt up, in that position)
Also doesn't explain what would then fill the hole in the dash? Unless maybe someone drilled that hole after - quite possible. I've seen photos of these trucks with the ignition in both that bracket, and in the dash.
OT Vehicles:
Bracket fits under dash with switch sticking through hole in dash. If you look under side of dash beneath ignition switch hole you will see 2 holes for mounting bolts
1949 gmc 1-ton
Maybe I should say behind dash. Rounded part of bracket will match rounded part of dash small hole in bracket for light socket
1949 gmc 1-ton
Ahhhhhhh OK thank you!!! That starts making sense smile
OT Vehicles:
Brilliant! That helps a lot!
Thank you!
OT Vehicles:
Moderated by  ndkid275, Phak1
