2 members (klhansen, Samantha),
51
Mod | | | Forums66 Topics128,053 Posts1,055,778 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | A couple of weeks ago I was doing some serious work with my 1/2” impact and had run the compressor for about 45 minutes. When I went to turn it off I found fire coming from the start capacitors. The motor was a replacement from about 10 years ago. So, I’ve spent the past few days rebuilding the compressor. New pressure safety switch/valve and new motor. Both came in today and I installed them this evening. Need to get a new belt and a Electrical Cutoff Switch, wiring and armored cable to hard wire the unit. Should be up and running by the weekend. It will be good to put the 6 gallon pancake compressor back on the shelf.
| | | | | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | My compressor pump recently seized. I tried to do a temporary repair with Harbor Freight parts, but it couldn't keep up. New IR is in place and hopefully the last compressor I will ever need to buy! | | |
