1 members (Bucker),
144
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2019 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2019 Posts: 37 | Have been trying to decide on a color for my truck. I think it is going to be red but that only narrows it down a little as there are so many to choose from. Was looking at going with the swift red since that was one of the original colors. After looking at what claims to be swift red trucks online they often appear to be different shades. Maybe just lighting and camera used makes them look that way. I am looking for a bright red. No orange tint. Just red. Looking for opinions of the swift red from anyone that has one or has seen one in person. Thanks.
1947 3100
| | | | | Joined: May 2015 Posts: 11,186 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,186 | That's the trouble with looking at colors on a computer. They look different depending on your monitor, and even the angle you're looking at it.
Here's a thought. Go to a paint store and have them mix up your candidates in a spray can and do a sprayout of each. A custom mixed spray can costs about $30-40. That way you can make your best choice out in daylight. Paint stores will have color chips and they'll let you take them outside to look at. But that can get overwhelming with all the different choices.
Good luck.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2020 Posts: 24 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 24 | If you want to paint your truck with a factory color, you can use paintref.com to check the paint code. | | |
