2 members (Gdads51, 1 invisible), 123 guests, and 2 robots.
Topics128,137
Posts1,056,471
Members48,441
Junior Member
Junior Member
Okay I decided to go with a fromn crossmember swap toupgrade to disc brakes. So what are my choices for a power brake master/bosster assembley; and yes I have a hydrolic clutch. Is the classic performance parts master/bosster asee,bley the only one on the market? At $450.00 that seems steep; any alternatives?
Check out Master Power brakes www.mpbrakes.com
also Engineered Components, Inc. www.ecihotrodbrakes.com for information on boosters and combinations.
Just a thought....are you sure you want to go the power booster route with your system. I'm very happy with the mid-70's Corvette manual Master cylinder, in both disc/drum and disc/disc configurations. I have power discs on my hot rod truck and find that they are a bit twitchy. My 54-3100 manual brakes with front discs are very predictable. The underfloor power booster/crossmember interference issues are something to consider. Check out these sites as well as www.911brakes.com and you might get a better response if you included a little more information on your application. Hope this helps.
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
I used the booster/master from a 1980 C10-had to drill a few holes but two lined up. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Junior Member
Junior Member
so what choices do I have for a clutch master cylinder?
Junior Member
Junior Member
I would suggest since you need to retain the clutch set-up,that just removing the residual valve from the "brake side" of the stock master cylinder,then plumbing the frt. brakes from the tee forward with 3/16"line, may be a solution. As Fla54Chevy3100 has said,Non-power disc have a great feel and work good. I realize that going Dual line master cylinder is by far safer in the event of master cylinder failure but I put many,many miles on my 54' single line master cylinder with disc/drum combo brakes.You might also want to plumb in a pressure regulator valve on the rear brakes.
BAN LOW PERFORMANCE DRIVERS...
NOT HIGH PERFORMANCE CARS !!
