4 members (Steelonsteel, Rich'sToys, Brian Moore, klhansen), 81 guests, and 2 robots.
Topics128,037
Posts1,055,465
Members48,422
#1365953 06/22/2020 4:03 PM
PA OUTLAW
PA OUTLAW
Replaced all metal lines on 1954 chevy 3100 with stainless steel kit from classic tube. Went to order rear hose was told lines were wrong size. can anyone the right size brake line on 1954 chevy 3100 THANK YOU IN ADVANCE!!!!!!!!!!!
jrhackett #1365967 06/22/2020 5:58 PM
Your brake lines should be 3/16" OD per the Master Parts Catalog.
More info on line lengths a few pages past the screen shot attached here.
jrhackett #1365978 06/22/2020 8:01 PM
Sir Searchalot
Sir Searchalot
Not sure what you are saying JR. Who said they are the wrong size? What size are they? If you are talking about the lines you got from inline tube, they would be the right size. Who are you ordering hoses from? Inline tube?
If you are needing hoses, buy hoses that fit your fittings. You will be OK.
The two common sizes of brake line are 3/16 and 1/4. It makes no difference which of those sizes you use.
Here is a comment from inline tube regarding general convention. "Disc brake cars use 3/16” tubing and drum brake cars use ¼” tubing."
So they either will go with OEM size or this convention, I assume.
jrhackett #1366017 06/23/2020 12:50 AM
Based on what I posted, 51-54 Passenger cars and 1/2 ton trucks used 3/16 lines. I also went out and measured mine (1/2 ton) and found 3/16 inch lines.
jrhackett #1366049 06/23/2020 9:13 AM
1954 Chevrolet 1/2 ton trucks had two sizes/diameters of brake lines.
1/4” and 3/16”
Jim Carter has/had an illustration on his website.
Also, on 1954 3100 Hydra-Magic trucks, the brake lines are routed differently compared to manual transmission 3100s. The “crossover” line to the rear transmission is in a different location.
jrhackett #1366120 06/23/2020 7:21 PM
Sir Searchalot
Sir Searchalot
The Line he got SKU: SCTB5401 is 3/16.
As Kevin shows, that there is correct! Buy the hoses from Inline so that if anything is wrong, fit/fitting wise, it will be on them.
