| | | Forums66 Topics128,157 Posts1,056,877 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 31 Apprentice | | Apprentice Joined: Jan 2006 Posts: 31 | I have a 57 chevy truck model 3100 with a Mustang II front end from TCI. I have a Ford Explorer 8.8" rear end. Want to install an e-brake system but cannot use the original bracket that mounted to the top of the frame above the drivers wheel, the top hat of the MII is welded there. Has anyone come up with an e-brake system on this setup that works well? I want to continue using the handbrake for the classic look in the cab. Thank you, David | | |
