1 members (Hotrod Lincoln),
79
0
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2020 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 60 | Will a 135 from a chevy truck fit in a 46 with out easy modifications. It looks like it has the same mounts front and back. Thanks for the help. | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | What is a "135"? There are several tech tips on this site that address adapting a 235 to your application. The year the 235 was manufactured makes a big difference in how much modification is required. Jerry
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Hog Wild, you need to proof read your posts. To directly answer your question, no the “135” will not fit in the ‘60 without easy modifications. Now to answer the question you really meant to ask, yes the 235 will fit in your ‘46 with easy modifications. Use the magnifying glass (search function) in the upper right corner of the page for thousands of answers and Tip on the process. Have fun with your project.ðŸ›
| | | | | Joined: Mar 2014 Posts: 4,484 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,484 | I'm disappointed. From the title, I thought the poster had gotten stopped doing 135 in a 60 mph zone and I wanted to see who in their right mind would be anywhere near an AD truck going 135 mph.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jun 2020 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 60 | What is a "135"? There are several tech tips on this site that address adapting a 235 to your application. The year the 235 was manufactured makes a big difference in how much modification is required. Jerry Yes sorry a 235. It came out of a 60 chevy truck. I know they changed engine mounts to side mounts but didn't know what year chevy did that. | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | There's still an option to front-mount the later model engines, since the earlier mounts were incorporated into the steel separator plate between the block and the timing cover. You can either install an earlier separator plate, or drill holes in the later one for the early mounts. Jerry
