3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#1365761 06/20/2020 11:58 PM
Will a 135 from a chevy truck fit in a 46 with out easy modifications. It looks like it has the same mounts front and back. Thanks for the help.
Hog Wild #1365815 06/21/2020 2:28 PM
What is a "135"? There are several tech tips on this site that address adapting a 235 to your application. The year the 235 was manufactured makes a big difference in how much modification is required.
Hog Wild #1365819 06/21/2020 2:54 PM
Hog Wild, you need to proof read your posts. To directly answer your question, no the “135” will not fit in the ‘60 without easy modifications. Now to answer the question you really meant to ask, yes the 235 will fit in your ‘46 with easy modifications. Use the magnifying glass (search function) in the upper right corner of the page for thousands of answers and Tip on the process. Have fun with your project.🛠
Hog Wild #1365823 06/21/2020 3:27 PM
Moderator, Electrical Bay
I'm disappointed. From the title, I thought the poster had gotten stopped doing 135 in a 60 mph zone and I wanted to see who in their right mind would be anywhere near an AD truck going 135 mph.
~ Jon
Yes sorry a 235. It came out of a 60 chevy truck. I know they changed engine mounts to side mounts but didn't know what year chevy did that.
Hog Wild #1365879 06/21/2020 10:55 PM
There's still an option to front-mount the later model engines, since the earlier mounts were incorporated into the steel separator plate between the block and the timing cover. You can either install an earlier separator plate, or drill holes in the later one for the early mounts.
