10 members (BarryP, mick53, Bill Hanlon, rfs56trk, Nick in Manitou, UtahYork, NorCal52Suburban, Hanks custodian, Donf, 1 invisible), 140 guests, and 3 robots.
Topics128,136
Posts1,056,745
Members48,454
#1365725 06/20/2020 7:44 PM
Hello All,
I have my chassis complete and rolling... now working on the body panels... Took them out of storage... bare metal panels had some light surface rust on them so I sprayed them with POR 15 Metal Prep. Kept it wet like the instructions said... all the rust had dissolved after 30 minutes so I rinsed it off...
Well after I rinsed it off, the rust on the surface was WAY WORSE... See below for before and after pictures... and yes the pictures are named correctly.
What did I do wrong? The whole goal was to eliminate the sanding... now looks like I will be working out the ole manual sander...
Any advise?
53 3100 purchased brand new by my wife's grandfather... full frame up restore in progress.
I used por metal prep then rinsed with a diluted por prep i believe it was 3 parts water 1 part metal prep then painted
I just finished a 1946 chevy pickup street rod
now on a 1950 chevy 3100
also a GMC 220 with duals
and a 1948 chevy 2 ton
Insomniac
Insomniac
Looks like "flash rust" caused by letting the metal air dry.
We dry the metal immediately after a wash with any water based product. Towel it off and blow dry with heat gun.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Ok... those ideas make sense... the flash of rust happens almost immediately as I am washing off the metal prep...
Below is the same inner fender after re-applying metal prep and letting it dry on the metal...
I guess I will try to dilute some POR 15 with water then dry it fast... smile
Moderator, Electrical Bay
Any high build primer will fill any small imperfections like that easily and quickly. You'll still have to sand, but you'd have to do that with primer anyhow. Good luck.
~ Jon
Scuff it clean, apply EPOXY primer which will prevent any rust creep as it's the only product that's designed to stop rust. After the epoxy is on, put anything over it as it just doesn't matter because the Epoxy is THE most important first step... including Pour products...
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
thank you for the feedback... I am using DP90LF epoxy primer... will grease/wax it clean then spray the DP90LF then paint...
Thank you again... this forum is just amazing.
Brilliant! You have taken the best approach!
~~ Darcy
FootStomper
