| | | Forums66 Topics128,050 Posts1,055,639 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 8 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 8 | I’m looking for a complete Original style exhaust system for a 1949 3800 with the 9 foot bed/137 inch wheel base. Does anyone know a source for one of these? I’m fairly new to the site and have never replaced an exhaust system before. It’s one of the last things I need to get my truck back on the road so any guidance is appreciated. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Have you checked with nearby exhaust/muffler shops? Waldron's Exhaust is excellent. | | | | | Joined: Mar 2016 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 225 | Tim is correct.
I used Waldron's on my 51 3100, complete exhaust from manifold to rear....every piece and part fit exact, all the clamps and hangers came with it, muffler looked like the original. A shade higher than what a local muffler shop wanted to do a complete system for, but I preferred the clamps and original looking hangers and muffler also. Very satisfied with what I got from them.
Mike
1951 3100 5 window
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | The muffler is the same as the 1/2 ton (1941-49). The Tail Pipe is 1-ton only (1941-49). The Exhaust Pipe is a one year only, but is the same for ALL 1949 trucks (exc COE). As others have said, any old muffler shop should have the "bend cards" to make your pipes. I may have them if all else fails, but check your local shop first. Mike B  | | | | | Joined: Jan 2017 Posts: 8 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 8 | Thanks for the quick responses - maybe I will look at buying the model specific parts and have the muffler shop fill in the pipes | | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | Jim Carter truck parts has the original mufflers. Buy one, and take to a skilled exhaust shop who can mandrel-bend the exhaust pipe, and route it right to where you want it to exit. Take a couple of pictures for them to reference. If you want to hear what the original muffler sounds like, PM me, I have a couple of good exhaust clips using the Jim Carter muffler.
-Patrick 1953 Chevrolet 3100 261 / 4-speed / 4:11 / Commercial Red
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | You should try to make the exhaust as quite as possible. Then you can start tracking down other noises one at a time for as long as you own the truck. At least, that's what I'm doing. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | At the Exhaust shop they will mount the muffler (Guy held it to pipe) you want and start the engine. I tried 3 before I was happy. First two too loud...lol Good luck and keep us updated. Todd
1950 Chevy 3100
| | | | | Joined: Jan 2020 Posts: 24 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 24 | A local shop did my exhaust also. I got the muffler from a salvage yard and then I bought the exhaust pipe at 4wheelonline. I was very pleased with the result. | | |
