4 members (55shaker, Cosmo, Gdads51, 1 invisible), 118 guests, and 2 robots.
Topics128,069
Posts1,055,896
Members48,428
#13650 04/08/2004 1:14 AM
I'm ready to install the oil filter option on my 53 truck with a 55' 235 stovebolt in it. I never really even thought about it until I was ready to put it on and realized that I have no information on where it is hooked up. This engine has a small hole in the head about halfway just where the oiler tube is under the valve cover. I'm sure that is the pressure side but where do I place the return line? Silly question to many I suppose but I have spent little time on 6 bangers and appearently didn't pay that much attention to the small things. Funny too is that of all the inliner info I have accumulated there is nothing at all about the optional dealer installed Fram filter.
I'm sure this will turn out to be one of those "it's so obvious you can't see it" deals and then I will feel like a dummy but that has never kept me quite before... wink
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#13651 04/13/2004 10:49 AM
Did you find an answer to your question yet?
I was looking through the past posts and found yours without any replies frown
I think Tony M has a pic of his O/F set-up on his `54
#13652 04/13/2004 2:21 PM
i'd like to see a picture of that setup, i am in the same boat with no oil filter but it's on "the list"
#13653 04/13/2004 3:20 PM
Here is a pic of my oil filter mounted on a 53 235 low pressure engine.
#13654 04/13/2004 4:49 PM
great pic! thanks
that engine bears some small resemblance to the grease and dirt covered hunk of metal under my hood, i think i saw some dirt actually running away from that engine in the picture!
