6 members (Woodcmiami, MNSmith, Otto Skorzeny, Guitplayer, Lostbuthaulinass, Gray_Ghost), 61 guests, and 1 robot.
Topics128,057
Posts1,055,812
#1365269 06/17/2020 3:30 PM
V
V Offline
I have decided to sell my 4500 mile 261. Unfortunately, when I received my 58 Viking the engine was frozen. Upon head removal I realized the head gasket had been replaced with what I believe was a
235 head gasket, no steam holes. This is as far as I went with diagnostics. In went a 283 and all I did with the engine was to nestle it inside a comfy shed and pour lubricants into the cylinders. The
cylinders are all now empty from leaking past the stuck pistons and or rings. Now to the question. Will I diminish the value of the engine by doing what is necessary to remove the pistons? Would a
potential buyer prefer to finish the dismantling of the engine themselves ? I would like to pull the pan and examine the crank and pistons, however I don't want my curiosity to kill the proverbial cat. Any thoughts or opinions would be appreciated.
Thanks, Rich
Rich
68 C30 CST dually flatbed dump
58 Viking 6500
viking58 #1365274 06/17/2020 3:44 PM
If you want to sell the engine, it might help if you can show/describe your conditions/findings?
Will you guarantee that the engine head/block are rebuildable?
viking58 #1365277 06/17/2020 3:56 PM
Moderator
Moderator
2 Offline
If I was a buyer, pulling the pan and looking at the rods, mains and pistons would be the first thing I would want to check out.
That way you can be more upfront with a potential buyer with more info on the condition of the engine.
Pull the pan and pee oil the bottom of the pistons for a few days.
Then see if you can get it to turn, to get a good look at the cylinder walls.
A buyer will want to see the inside and then make an offer.
Not looking is like rolling dice, when buying a non running engine.
Just my 2 cents.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
