0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2016 Posts: 53 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 53 | I have decided to sell my 4500 mile 261. Unfortunately, when I received my 58 Viking the engine was frozen. Upon head removal I realized the head gasket had been replaced with what I believe was a 235 head gasket, no steam holes. This is as far as I went with diagnostics. In went a 283 and all I did with the engine was to nestle it inside a comfy shed and pour lubricants into the cylinders. The cylinders are all now empty from leaking past the stuck pistons and or rings. Now to the question. Will I diminish the value of the engine by doing what is necessary to remove the pistons? Would a potential buyer prefer to finish the dismantling of the engine themselves ? I would like to pull the pan and examine the crank and pistons, however I don't want my curiosity to kill the proverbial cat. Any thoughts or opinions would be appreciated.
Thanks, Rich
Rich
68 C30 CST dually flatbed dump 58 Viking 6500
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you want to sell the engine, it might help if you can show/describe your conditions/findings?
Will you guarantee that the engine head/block are rebuildable? | | | | | Joined: Aug 2001 Posts: 3,596 Moderator | | Moderator Joined: Aug 2001 Posts: 3,596 | If I was a buyer, pulling the pan and looking at the rods, mains and pistons would be the first thing I would want to check out. That way you can be more upfront with a potential buyer with more info on the condition of the engine. Pull the pan and pee oil the bottom of the pistons for a few days. Then see if you can get it to turn, to get a good look at the cylinder walls. A buyer will want to see the inside and then make an offer. Not looking is like rolling dice, when buying a non running engine.
Just my 2 cents. Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | |
