1 members (RLB), 215 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#136521 12/29/2006 3:57 AM
I have a 1948 3/4 ton that has a rock solid body. I want to build a driver that I can enjoy in todays traffic conditions. I am thinking of building a mild resto rod with a Mustang II front end, 350 engine, auto transmission, power brakes, air conditioning and updated rear end and rear springs. Does anyone out there have any experiences they would like to share about updating a 3600.....I know alot can be done with a 3100 as far modern components but I am not sure about a 3600. Thanks, Scott
#136522 12/29/2006 4:25 AM
You can do pretty much anything to a 3600 that you can to a 3100. The front halves of the frame are the same so the MII front end is not a problem. The rear half of the 3600 frame is narrower than the 3100 and of course longer.
The 3600 rear springs are hung outboard of the frame rails and the 3100 are hung underneath the frame rails. I recently saw a rodded 3600 with a low down in the weeds stance and it looked pretty cool with that long box.
Steve
'49 3800
'52 3600
'57 3100
#136523 12/30/2006 3:44 PM
The only other thing I can think of that Ghostrider didn't say is you might need a 2 piece driveshaft.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#136524 01/04/2007 2:11 AM
Ghostrider and Wilbur, thanks for the reply. Would the original rear springs and shackles be able to handle a mild 350 ? If not has anyone used a different set of rear hangers and springs? I have heard differing opinions about the drive shaft situation. I would think I could have a one piece drive shaft made to fit.
#136525 01/04/2007 2:52 AM
I think the springs would be fine with a 350, but they will give a stiff ride and it will sit too high in the rear if you're going MII in the front. You'll probably want to change them out or possibly remove some leaves or de-arch.
I think a one piece drive shaft will be a little long on that truck. A lot of differing opinions on this, but I think your maximum length is going to want to be in the 50" to 55" range from what I've been told or read in the rodding magazines.
Steve
'49 3800
'52 3600
'57 3100
#136526 01/11/2007 4:45 PM
1 Offline
sweet! i am building a '59 3600 resto/rod. long and low, should look good.
77 nova clip, 10-bolt, th350, 3-link rear suspension, 385 sbc.
i haven't gotten my engine/trans in to measure, but the truck had a one piece driveshaft stock.
2003 ford lightning
1959 chevy 36
