3 members (RoadsScholar, Gdads51, Gray_Ghost), 120 guests, and 4 robots.
Topics128,078
Posts1,056,021
Members48,433
#1364915 06/14/2020 11:22 PM
suddenly can't start my 250... if I pour gas down the carb it will start but not otherwise... put a new fuel pump on.... no change any ideas?
Put gas in tank ???
1965 c-10 4 wheel drive conversion
Pix in the Gallery Forum
The quality of fuel pumps is not what it used to be. Test the new one to see if it works. Long rubber hose connected to the pump intake running to a separate fuel source with fresh fuel.
Sir Searchalot
Sir Searchalot
Agree with Martin.
If fuel pump is mechanical:
Take center wire off of distributor so it won't start. Run a hose from a good, clean gas can near front tire, on the ground, into pump inlet. Run the pump outlet into a container, like a water bottle. Crank motor. Should see pulsing good flow. If you get a good flow, hook tank hose back up and leave outlet into a bottle. Crank motor. If both test show good flow, it's the carb.
Good flow in these two tests eliminates:
1. Pump
2. Lines
3. Filter
4. Clogged tank pick up
5. Tank not venting
6. Tank gas level too low
Other results of these tests give great clues.
Before pump test, look down carb throat, motor off. Operate throttle, see if gas squirts out inside throat.
Thank you for your kind response I will follow your instructions and see what happens..... I've got a 1966 C10 long bed which is full of holes but I'm hoping to restore it ... once again Thanks
