| | | Forums66 Topics128,036 Posts1,055,454 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | How do you activate the defroster on a 46 Chevy truck? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | grasp the crumpled newspaper firmly in yer right hand .... the defroster on the old heaters is just a lever on the heater that directs the air flow to the floor or to the defrost ducts, so it's a manual "on or off", and usually the lever doesn't stay in a part way position on oldies ... you do have a heater? Bill | | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | The truck has been retrofitted with Vintage Air, so I guess I will have to call them! The unit seem so odd they way they put it in.
Thanks for the heads up on the old trucks having a lever on the heater to direct the flow!!
Dan | | |
