Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Ponchogl, Otto Skorzeny, truckernix, TooMany2count), 122 guests, and 1 robot.
Topics128,277
Posts1,058,453
Members48,490
#1364277 06/10/2020 4:35 AM
Fox
Offline
Hi all,
I’m looking for the brake line sizes for a ‘70 C10.
What line on the rear axle?
The line to the front frame cross members.
To the master/prop valve.
To the front wheels.
I got this truck disassembled and have no idea. Anyone have pictures for a fella?
Thanks.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
I installed a dual pot MC in my son’s 1968. No booster yet. New 1/4” copper/nickel lines to the front drums and 3/16” lines to the rear. I have an adjustable brake bias valve in the rear brake line circuit too.
Insomniac
Insomniac
Do you have disc brakes up front? They were standard in 1971...probably an option in 1970.
If you have the disc brakes, the master cylinder and combination valve will guide you on the line sizes.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Disc brakes were not available in '70, became standard in '71.
BC
1960 C60 pasture art
Fox
Offline
I have converted the front to disc brakes, hence another reason why I don’t know what is exactly supposed to be there.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Insomniac
Insomniac
So you should have one of these: https://www.carolinaclassictrucks.com/172-572.html
The diagram shows the fitting sizes. I took the combo valve with me to the auto parts store when I bought the lines to make sure I had the correct fittings.
Gord 🇨🇦
