6 members (GRNHydra, Oswald, Southerntruck, 1955 1 Series, Nick in Manitou, Wayne67vert), 122 guests, and 1 robot.
Topics128,124
Posts1,056,334
Members48,439
#1363803 06/07/2020 11:18 AM
My driver side door sags while open. The bottom door side side hinge is loose. I have to lift it up to close it. Can this be repaired? If so, how?
Door side hinge
It looks like the pin/bearing holes may be worn. Some of the vendors sell oversize pins and you can drill the hinge body and install the oversize pin to take out the slop.
There are some tips on hinge restoration/repair in the Tech Tips Section of Stovebolt.
back yard wrench turner
W Online: Content
My doors had the same issue. The area around the hinge had broken loose. I had to weld the hinge area back to the door. There are door check stops that are supposed to keep the door from putting stress on the hinges. Mine were missing.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
I suspected that was the case. My door stops are missing.
There are also replacement hinges available if needed. Not cheap but sometimes there aren't many choices.
38 Chevy 1/2 ton being resto-moded
65 AC Cobra replica
USAF vet
