1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2016 Posts: 42 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 42 | Hi legends, I’m building a 1.5 ton truck, but to get enthusiast registration I need to lower my GVM and as it seems disc brakes are easier on the 3/4-1ton axle I’m looking at options for that.
So my questions is a multi pronged
From what I can work out the TSM and nostalgia SIDS use early C20 calipers (I love this idea because if I make an issue parts are available even if tsm / sids stop doing them but what is the doc they are using? Is it something else machined and modified?
Is there a way of doing Disc brakes aside from these two kits?
Thanks heaps
Yeti? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Yeti, 'Doc', is that meant to be disc? TSM used C20 and similar discs, however they are not rated for 1.5 ton, unless the GVW falls in the 3/4-1 ton axle range. The disc used depends on bolt pattern, do you have 8 on 6.5" or 5/10 on 7.25" or something else?
Ed
| | | | | Joined: Sep 2010 Posts: 1,711 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,711 | I put discs on my '38 1 ton. Mine are 6 lug. I used late 70's parts. Caliper is C10, rotor is K10. I fabbed up the bracket using plywood to get to the final rendering, then cut out of 5/16 steel. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Mar 2016 Posts: 42 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 42 | Yeti, 'Doc', is that meant to be disc? TSM used C20 and similar discs, however they are not rated for 1.5 ton, unless the GVW falls in the 3/4-1 ton axle range. The disc used depends on bolt pattern, do you have 8 on 6.5" or 5/10 on 7.25" or something else?
Ed To make it work I’m going 8 on 6.5, I understood this lowers my capacity considerably and this actually suits
