Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
9 members (Stovebolt48, Drew54, tclederman, J Lucas, Maybellene, Otto Skorzeny, 2-Ton, klhansen, 1 invisible), 110 guests, and 2 robots.
Topics128,281
Posts1,058,488
Members48,490
#1363736 06/06/2020 8:55 PM
I disassemble my head and had it resurfaced but couldn't get back to it until now. I took several pictures which help but I didn't capture the detail I should have. Can anyone point me to a diagram showing detailed view of each part and order they go in.
Colton Kenshol
Hermiston, Oregon
1950 Chevy 3100
216 Motor
Mostly Original..
I've done that. Shop manual has no details or drawings
Colton Kenshol
Hermiston, Oregon
1950 Chevy 3100
216 Motor
Mostly Original..
Exactly what are you having trouble with...valve install, rocker arm and shaft? Maybe we can help with a little more info...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
theres always the Hagerty rebuild of the head on youtube
woof359 Family 1952 3100 5 Window
Just a couple small issues Im not totally sure on.. Example... There are two different types end pieces that sandwich the valve spring.. Just not sure if they go on the intake or exhaust valve springs.
Colton Kenshol
Hermiston, Oregon
1950 Chevy 3100
216 Motor
Mostly Original..
Ex Hall Monitor
Ex Hall Monitor
I don't know if this'll do you much good. It's a small image but the best I have. On my 216 the valve keepers are the same on intake and exhaust.
Thanks Tiny, Unfortunately is doesnt help. What I need is an expanded parts view of an intake and exhaust valve assembly. I appreciate the help though. Just surprised I cant find the information, You would think that it would be important enough to be in the shop manual.
Colton Kenshol
Hermiston, Oregon
1950 Chevy 3100
216 Motor
Mostly Original..
Can you post a few images of these "two types of end pieces" ?
