5 members (Lugnutz, F100Ranger, 55shaker, Otto Skorzeny, Steelonsteel), 88 guests, and 4 robots.
Topics128,140
Posts1,056,466
Members48,441
Hi legends, I’m building a 1.5 ton truck, but to get enthusiast registration I need to lower my GVM and as it seems disc brakes are easier on the 3/4-1ton axle I’m looking at options for that.
So my questions is a multi pronged
From what I can work out the TSM and nostalgia SIDS use early C20 calipers (I love this idea because if I make an issue parts are available even if tsm / sids stop doing them but what is the doc they are using? Is it something else machined and modified?
Is there a way of doing Disc brakes aside from these two kits?
Thanks heaps
Yeti?
Crusing in the Passing Lane
Yeti, 'Doc', is that meant to be disc? TSM used C20 and similar discs, however they are not rated for 1.5 ton, unless the GVW falls in the 3/4-1 ton axle range. The disc used depends on bolt pattern, do you have 8 on 6.5" or 5/10 on 7.25" or something else?
Ed
back yard wrench turner
I put discs on my '38 1 ton. Mine are 6 lug. I used late 70's parts. Caliper is C10, rotor is K10. I fabbed up the bracket using plywood to get to the final rendering, then cut out of 5/16 steel.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Ed
To make it work I’m going 8 on 6.5, I understood this lowers my capacity considerably and this actually suits
