Topics128,040
Posts1,055,474
Members48,424
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
1952 3100 Chevy, there's an open hole in the right kick panel , is there suppose to be some sort of vent grill in there covering it ?
woof359 Family 1952 3100 5 Window
That's the opening for a fresh air heater. If one is not installed, there would be a solid cover screwed in place over the opening.
1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car)
thanks, got a Chevrolet heater and there a metal panel over the hole but its not a match with the screw holes
I have the bottom round one that doesnt cover the hole, now I need to find a replacment plate, Thanks for the info
Thanks Brad, found the plate, cleaned it up, holes in the kick panel were screwed up but it better than it was, Thank you
Attachments h1.jpg (93.56 KB, 57 downloads) h2.jpg (88.41 KB, 58 downloads) h3.jpg (78.35 KB, 55 downloads)
